Matrix bits
  • Big Lee M
    • 2571
    Matrix bits
    I'm thinking of having the matrix very shortly if the anything that should be replaced while having it done,while the dash is out? Such a seals for the air-con?
    Any help would be great,cheers Lee
    Just some finishing touches to do now
  • johne
    • Apr 2007
    • 1406
    Lee, there are no seals in the air-con system pipes behind the dash. The pipes for the air-con are solid until they emerge through the bulkhead and connect on the engine side and those seals are easily reached.
    However, the low pressure switch for the air-con is behind the dashboard, sandwiched between the evaporator and the bulkhead above the ECU. This switch does have a seal and also the air-con can't work if this switch fails so you could consider replacing it "just in case"
    John
    • Big Lee M
      • 2571
      Cheers for that. I had it all checked last summer and it all worked fine other than a split pipe which I have now. So all I need to do is get the matrix done put the pipe on and I'll have aircon and a heater that works right! At last. But time will tell!
      • Crawford_S2
        • 1555
        Ordered the matrix for mine today
        Can't believe i have to take the ferkin dash out to do this! Just about to give up on this S2 ownership thing, but not quite yet
        Ragusa Coupe gone!
        • Big Lee M
          • 2571
          Take lots of pics I've been told? And let me know how you get on,so I can make my mind up if I should do mine??????? But it looks like a real PITA job. GOOD LUCK!
            TBH its not that bad a job once you get into it, just time consuming
            • Crawford_S2
              • 1555
              How long should it take, with a few fag and brew breaks?
              Ragusa Coupe gone!
              • quattrodude
                • Apr 2008
                • 140
                iv also gota do this soon as my matrix has been leaking for a while, how much are the matrix and wheres best place to get 1??
                The fun starts at the turn of a key
                Quattro power here we go!!
                1993 ABY S2 coupe,
                • spink
                  • 4382
                  If you get a mate or 2 to help it makes the job so much easier,we did one in about 3-4 hours a few months back but set aside at least a weekend if you aren't familiar with the dash and all its attachments.
                  • Acidburn
                    • 13459
                    To remove a dash is easy, about half hour to remove it and an hour to put it back in if you know what your doing, I've done it on at least 4 cars now, the s2 being the next one that will get the treatment as i've got a mint dash to go in mine, I did a thread a while ago with some pictures etc when I removed the dash from a 20v.
                    • Crawford_S2
                      • 1555
                      What about the aircon, does the system need to be degassed and disconnected? Is there no way to do this and leav the gas in, i just had it filled!
                      Ragusa Coupe gone!
                        look for signs of water leaking near the fusebox, easier to see than with the dash in!
                        • johne
                          • Apr 2007
                          • 1406
                          If ur prepared to risk a secondhand one there's lots of choice as it's the same on the 80 and the early A4.
                          John
                          • johne
                            • Apr 2007
                            • 1406
                            You should be able to leave it filled. Take the dash out. To replace the matrix you only need to remove the central part of the heater. After removing the clips holding the central part to the A/C evaporator which is the part in front of the passenger, you can get the central part out. The challenge will be getting all the clips back but it'll save you having to degass the system.
                            John
                            • Crawford_S2
                              • 1555
                              John
                              Sweet! Gonna start this tomorrow, got the service and pads done today and a tinker with the new project before it got dark so got the whole day to do this
                              Ragusa Coupe gone!
