Last night I got home and the after run fan was spinning away nicely. Ive had problems in the past so I went back to check it had stopped 30 mins later and it will still spinning. I wasnt in the mood to deal with it in the dark and cold so left it to drain the battery. This morning I had a good look, with the help of S2_bo, many thanks! We hooked it up to a battery, disconnected the switch and the fan still spun up, the only way we could make it stop is to disconnect the relay which i have done.
So, finally to the point...sorry. Bo told me there is another sensor at the bottom of the rad which might be the problem. My quesiton to you; has anyone got a spare I could use to see if that is where the fault lies? and with a view to buy it if it does fix the problem!
Any other hints or advise welcome!
Thanks all
Thanks all
