Front window blower keeps goint no matter what?!
  • Jonas_R
    • 3781
    • Country: Denmark
    Is there any way to turn off the front blower, the one in the middle of the dashboard, that blows directly on the front window?
    Because it wont stop when i turn off the climate control and iam going insane with the noice! Is it not suppose to stop? I have even try to pull out the plug on the climate control, but the damn thing keeps blowing.... This is very frustrating, so any adwise on how to make the damn thing stop would be very nice!
    Best Regards
    /Jonas R.
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • ramen
    • Jul 2004
    • 3
    • Home: Sweden
    I have the same problem... anyone got a solution?
    • A80Avant
      • 10873
      • Country: Greece
      what type of a/c do you have? climate electronic or manual knobs?
      if you have the first then just turning it off should work,if not,then when ON press the button that brings air from the face blowers only or the feet so that the flap turns that way rather than the front windscreen.
      if you have the knobs,try turning them towards the feet.that would again close the flap.
      • ramen
        • Jul 2004
        • 3
        • Home: Sweden
        climate electronic... and you are right when I press the OFF button it will turn to my feet but why doesn´t it stop blowing? I have tried to change the panel and blower but no change... everything works but not the OFF button!
        • A80Avant
          • 10873
          • Country: Greece
          do you have a VAGCOM? or equivalent? the electronic climate may give you a fault code in there!
