I have a problem with the main radiator fan running the time, it runs with the ignition on and off, when the car is hot or cold. It runs when i pull fuses no 5(30A) no 15(25A) and no 20(30A). It runs when i pull them one by one or all at the same time . I have replaced the dual thermo switch in the radiator part no 191959481C with a brand new one. I have replaced the fan it's self with a new fan but is still runs.
The only way a can get the fan to stop is to pull the no 3 relay the radiator fan delay or disconnect the battery.
so........
A) is the afterrun switch jamed closed/stuck on? which would make the main fan run at speed one as per
B) the resistor pack ******ed?
C) the main switch for the fan closed/stuck on? (I'm a bit lost here as i thought the thermo switch was the fan switch?)
A/C disconnected if this helps
please help
thanks in advanced
cheers
John
so........
please help
thanks in advanced
cheers
John
wish I hadn't rolled my S2... I'd still be sampling the interior on a frequent basis.
