New a/c compressor fitted
This is a sticky topic.
  • jade
    • Jan 2005
    • 1811
    • Home: New Zealand Current: Spain
    I suspect that Zexel pump is indeed very common... S2/RS2 gets a variant without the compressor speed signal and an oddball pulley compared to other models. Great find Rich !
    Mine was replaced by a VW Passet one, just cut the wires to the speed sensor, It was supplied by the company below One year on it still good, I will check the brand because I do not think it was a Zexel one
    RS 2 580HP
    • darkhorse1210
      • May 2010
      • 335
      Grab one whilst you still can....
      Matching part number 8A0 260 805 AF
      I spent hours and hours searching for one at a reasonable price and found one here:
      http://www.ebay.co.uk/itm/BRAND-NEW-...item1c1d2b9141
      Delivered within 36hrs and it's genuine Valeo.
      Hopefully this will save many of you time and money.
      • darkhorse1210
        • May 2010
        • 335
        Compressor end connection dimensions
        Looks like I'll be going to Demon Tweeks at the weekend to try and sort the new pipe/fittings.
        As my new condenser is non OEM I have a different thread size to normal at that end of the proceedings, it is:
        M22 x1.75
        My question is what are the equivalent dimensions for the compressor end (i.e. to fit the compressor in the EBay ad I posted above)?
        Compressor part number is:
        8A0 260 805 AF
        Can anyone provide this so I don't look like a complete amateur when I arrive at the desk!
        It's looking like I'll try and get a custom Goodridge hose made up. Does anyone have any advice?
        • BorisShakhov
          • Feb 2009
          • 224
          • Country: Russian Federation
          Guys, is there any solution to make a stop function for the compressor on high revs? My new one unit died after some race action...
            The compressor clutch should deactivate on WOT AFAIK.
            • rj scotty
              • May 2006
              • 2195
              #21
              high revs, causing higher pressure, causing leak to appear, causing low pressure switch to open preventing the clutch from kicking in? just a thought.
              But as pointed out above there is a full throttle inhibit function on the system
              BUT I DON'T WANT A NEW CAR!
              1995 S2 Avant, Volcano Black
