What antifreeze to use?
G12 is a 5 year antifreeze but wasn't meant to mix with other brands hence the need to flush the cooling system out throughly if you changed to it.
G12+ is the same but mixes with other brands of antifreeze.
It's always best to flush the system through with clean water when you change the antifreeze anyway.
G12+ is the stuff to use from the Stealers or GSF who sell it as a Febi generic brand - and it matches Jamo's ties - apparently
JohnComment
G12 Plus Plus is the new of coolant developed for the latest generation of alloy engines such as the W12. G12 Plus Plus coolant can be mixed with either blue G11 or pink G12 coolant like G12 Plus can, but it also includes updated additives.Comment
