Last year i took the S6 off the road over winter as i do most years. One of the jobs i did was a cambelt change. As a precaution i changed the water pump with one i ordered by parn number from GSF.
Ever since i did that the heater has been rubish unless the car is over 4500rpm
Is there a slightly different pump that i could have ordered my mistake? Or is it more likely to be something else that failed at the same time as a coincidence?
The engine is still warming up as normal.
, code 53 is the coolant temperature. It displays this as 8
Thats what you get for trying the do the job 'right'
