3B aircon compressor?
  • PeterS
    • 425
    Friend of mine pulled the compressor, condensor, evaporator from his 90q20v 7a motor, which I believe is the same as the 3B S2...he weighed the parts and the came to a total of less than 20kg....which is less than one would expect.
    However, the bulk of that weight is ahead of the front axle, so there are still benefits in handling to be gained.....
    -peter
    Peter S
    1990 ErsatzS2 - track toy
    1991 Coupe Quattro
    1991 Coupe Quattro
    1995 S6 Sedan
    1995 S6 Wagon
    • dan_b
      • Sep 2003
      • 3670
      Lee pulled his Aircon out, I think he said it weighed 18kg.
      Thing is, I want aircon! I hate being too hot behind the wheel...
      • dan_b
        • Sep 2003
        • 3670
        Does anyone have the part number for the 3B aircon compressor, and what other models used the same unit - want to find out if there are any manufactuers who do the same units cheaper than OE.
        • porkkis
          • 1994
          Nippon Denso 10P17C series
          034 260 805 D
          A100, A80, A90, Coupe from MY 87 to MY 92 (later ones are r134a)
          • The Spanish
            • Nov 2003
            • 719
            #20
            Here in Madrid the Compressor unit from the ABY is no use. If I use it is one compressor a year (as Audi gives warranty over parts for 1 year) I have manage to break it in around a year so I could get a new swap (I got 3 for free)
            Last two years I have not use it so I am sure is going out this summer without warranty.
            Wouldn't it be possible to fit a unit from an A3/A4/A6 etc... Any modern one that can cope with the weather and even better not take so much power of the engine?
            Pipe reworking is much cheaper for me than 1 compressor a year.
            94' RS2 Coupe TT (Twin Torsen )
            • The Spanish
              • Nov 2003
              • 719
              #21
              034 260 805 D
              Petri,
              ABY is supposed to have the r134a, correct?
              Is this one suppose to be good?
              Everytime I turn on the A/C the engine sounds a little "asmatic". When I fit a new compressor it takes 2 weeks before it sounds the same.
              Is the Denso replacement better than the OE (I suppose they should have put new technology into it)
              Thanks
              • porkkis
                • 1994
                ABY compressor is not Denso.
                I'm no A/C expert so can't answer the rest, sorry.
                • tajgreidotu
                  • May 2008
                  • 324
                  • Country: Spain
                  #23
                  I know this threat is old but Ive found what seems to be a seal kit for denso unit (3b) if any interest.
