dia of heater matrix feed&return pipe
  • here2learn
    • Feb 2012
    • 325
    i have removed my heater matrix and need to put a u bend hose from the out and return feed on the block but like a plum forgot to get the dia to order hose and jubly clips.
    what engine is it?
    • here2learn
      • Feb 2012
      • 325
      3b
      cheers
        If its a 3B the pipes are all the same diameter. you can bypass the matrix with an L-shaped hose between the external water pipe and the outlet on the back of the block. IIRC it is 22mm. HTH
        • here2learn
          • Feb 2012
          • 325
          cracking cheers
