i have removed my heater matrix and need to put a u bend hose from the out and return feed on the block but like a plum forgot to get the dia to order hose and jubly clips.
If its a 3B the pipes are all the same diameter. you can bypass the matrix with an L-shaped hose between the external water pipe and the outlet on the back of the block. IIRC it is 22mm. HTH
