S2 compressor not working
  • rynaqui
    • Mar 2012
    • 2752
    • Country: Malta
    So I've revamped the aircon in my S2 and compressor won't come in, when we tested to see if current was flowing to the compressor, there was none.
    What could be the reason for no flow of current?
    Any help is appreciated!
    1996 S2 ABY Silver
  • veneto rs2
    • Jun 2006
    • 1022
    • Country: Veneto
    One thing that can cause this it's the MFTS
    One of the functions of this MFTS it's to put off the aircon on high temps to protect the motor from overheating.
    This sensor was causing no power supply to my aircon in my exS2 3B
    An easy way to check this it's loose the plug from the MFTS and check if the compressor kicks in if it does you have two options:
    loose the wire that connected with the aircon system and leave it disconnected and leaving the others connected in this way thoug you will loose the "protection" on high temps of the cooling liquid that switches off the compressor
    Or change the MFTS
    Stefano
    http://www.audisportclub.com/
    • rynaqui
      • Mar 2012
      • 2752
      • Country: Malta
      Thanks for your help Stefano
      My mechanics actually pulled off the cover under the steering and apparently the cause was a loose connection. I've got A/C Now
      1996 S2 ABY Silver
