Hi all,
My LHD RS2 (with digital aircon) doesn't have a working AC anymore since 2 years.
I'll try to describe as good as possible.
- System filled correctly with right amount and doesn't leak.
- AC icon works on display
- all functions from ventilation work OK
- only fault code with 01c diagnostic stuff is 15.7, something intermittent about flap
- AC clutch voltage reads 12v on diagnostics, but read below...
- AC clutch relay 267 under dash doesn't click when putting on aircon, jumped pin 30 and 87 but didn't do anything.
- all fuses are OK
- I don't measure any power at the green-wire connector close the the AC compressor
- disconnected the MFTS but no difference
What are the other things I should check?
Big thanks in advance, it's tooo hot without a working AC these days
- all fuses are OK
