blower only works on no 3
  • Vinny
    • Apr 2013
    • 222
    I didnt disconnect my battery and it works fine just made sure ignition was off.you wont belive how chuffed you will be it only takes ten mins.
    • andy10v
      • 5996
      Originally posted by bungle74
      I got one of these from AudiBits2 for my non-aircon 94 Coupe. You say it just clips in, is that right? I've yet to fit mine but looked like it needed to be screwed on. Also, probably a stupid question but do I need to disconnect the battery first?
      Lee
      Yup just clips in.
      I have never disconnected the battery, changed 3 no issues.
      Sold ABY-stock
      • Vinny
        • Apr 2013
        • 222
        Mine just clipped together I rook thw glovebox out which was just two screws then it was up to the left directly ontop of the blower I undid the two catches on front then it just lifts out I just made sure ignition was off and all was good any probs my no is 07795482508 good luck from vinny.....
          Glad you got sorted with it
          • Vinny
            • Apr 2013
            • 222
            Cheers error works a treat its amazing how little things we can fix makes us feel like Einstein ...
              Yup, nothing better than those short periods of time you get occasionally where everything works properly
              • bungle74
                • Nov 2011
                • 87
                ******! Just put the new one in & it still doesn't work (yes, I have checked I didn't put the old one back in) I guess it must be a duff one. I might just send it off to be repaired rather than chance another eBay jobbie!
                Bit gutted though as I should have changed it when I brought it from eBay back in June, bit late to send it back now.
                • johne
                  • Apr 2007
                  • 1406
                  Check the thermal fuse with a multimeter, it's almost certainly that that's blown, the resistors themselves are bulletproof.
                  Cheaper and easier to replace the fuse than send it to be repaired or buy another ebay one.
                  I guess I'll have to set up a thermal fuse replacement service
                  John
