Found the bracket in the parts catalog too. 895 260 759 A
AC Pic request - hose & drier behind wing
Part no 1 in this diag. looks like it might be a drier bracket
Yeah there was a plastic bracket available for the 7A but its NLA now, and I'm not sure the drier fitted in exactly the same place as the hoses & pipes are different. I've got all ABY gear to go on minePanthero Coupé quattro 20vt
ABY-specific part 895 260 759 A seems to be extremely rare. You even can't find an image of it in the internet.
There is a very wide-spread plastic bracket 8A0 260 197 A. It has been fitted to lots of audi 80 B4/ Coupe since '92 model year. And it seems to fit 3B setup.
picture url
picture url
I have a B3/early coupe drier bracket 893 820 197. It is of steel. I can make a photo, if needed.
Funny, my 1991 CQ has a metal bracket but on the inside of the front rail. I'll try to find a pic. Some earlier US CQs had the lines running around the outside as well. I forget if my friend's '90 is this way but I'll look when I get a chance. IIRC, the dryer is still on the inside like my '91 but the ports are different.
*edit
Ignore the mess; you can see the dryer just under the turbo. I ended up pulling it.
Some pictures of where it is on a V6, nothing like a S2 but the part number matches.Attached Files
Some of the above pictures are mine Have a look at the full post on http://www.s2forum.com/forum/showpos...7&postcount=63 HTH
JB2001 996 C4 - Being renovated
1994 ABY Coupe - "Das Smaragd RS2+ Coupe" - Sold
