Hi guys.On my S2 Coupe ABY air con will not blow cold air unless i will increase engine speed to approx.1800 rpm.is it going to be compressor or some other component might be faulty.?
No Air Con on idle speed
Compressor is certainly the likely culprit but worth checking that your radiator fan comes on at low speed whenever the compressor is engaged and if dirt has got into the system at any stage the restrictor could be partially blocked.
To be sure of knowing what's going on you need to connect pressure gauges, one each to the high and low side, and see what pressures you're getting at different RPM. The high side is easy enough to get to in front of the radiator but often the only connection to the low side is in the passenger footwell up behind the Motronic ECU.
JohnComment
