Air con leak
  • 4WDrifter
    • Nov 2012
    • 1251
    Air con leak
    Hi guys,
    I left the S2 up the other day to get the air con re-gassed. It hasn't worked in my time owning it (about a year and a half).
    The chap said that he couldn't get any pressure into the system and that there must be a pretty big leak somewhere.
    Any idea where the leak is likely to be? What would the best way be to fix it, will the pipes need to be replaced?
    1996 S2 ABY Coupe silver
    2003 S3 8L dolphin grey
    2014 RS4 B8 prism silver
  • valjo
    • 1110
    • Country: Latvia
    i had mine regaseed about month ago (after 4 years without gas). I had to replace condesor and all hose seals
    they could put some color gas in so you could spot where it leaks ...
    Audi Coupe S2 1993
    Audi V8 4.2 1993
    Audi cabrio 1998
    • shaun5
      • 1610
      the pipe you can see in the o/s wheel arch will more than likely have a big hole in it.
        thats the most common failure on an ABY. Looks like this:
        • anthonys2
          • 3512
          I had mine re-gassed 3 years ago after a slight leak they are easy to trace they gas them and put a dye in this traces the leak if they are a decent company they should track it ok?
          • johne
            • Apr 2007
            • 1406
            Need a group buy to replace this pipe with a custom flexi
            John
            • 4WDrifter
              • Nov 2012
              • 1251
              I knew about the dye and was expecting them to tell me where the leak was, but they couldn't get any pressure in the system at all to get the dye in! The machine was saying to check that it was actually connected to the car lol.
              • 4WDrifter
                • Nov 2012
                • 1251
                Thanks for the guidance here lads, I'll keep you posted on how I get on.
