Coding New Climate Control Unit in VAGcom
    Can anyone help me learn about coding an item in vagcom?
    I have a new climate control unit I want to code, but not sure what I need to code it to - how do I find that out?
    I saw Si posted here about coding a CCU, and 00051 sounds like it should be the right code but not sure where this info comes from?
    Alex
  • rj scotty
    • May 2006
    • 2195
    Are you using the H suffix controler?
    BUT I DON'T WANT A NEW CAR!
    1995 S2 Avant, Volcano Black
      Not at the moment, I currently have a C4 unit but the new one is the A4 "H" suffix unit.
        I searched on here already - no luck yet - sure it was discussed at length before. I can dig out the factory info for climate coding but 00051 does sound familiar - needs to be for RHD and the compressor without speed signal. Did you keep the compressor from manual aircon - Zexel right ?!?
        • rj scotty
          • May 2006
          • 2195
          A4 H suffix coded 41 I think (will check in the morning) is what I have.
          Works perfectly but returns a fault code for coolant temperature sensor not being connected as there is not one on the s2.
          Dose not effect the operation of system at all
          • andyg plym
            • Nov 2006
            • 4646
            I fitted a urs4 to mine it was a straight swap, no coding etc
            Obviously being a left hooker mine came with climate etc
            • rj scotty
              • May 2006
              • 2195
              Do me a favor please Andy, next time your bonnets up, have a look if there is a coolant sensor on one of the heater matrix hoses.
              cheers
              • andyg plym
                • Nov 2006
                • 4646
                cheers
                From memory mate there is a blue switch on one of the heater matrix hoses
