As i described my AC does not works properly.
No matter LO or HI its blows the same temperature air.
I was changed cabin filter,but that was not the problem.
I think not the gas is the problem because the strength of the air is
fine.
in the hidden menu n channel1 i can see 15.7 but untill now i could not find what doest it mean.
Furthermore i can not step in the channel1 if there is more faults,or how can i see multiple faults?
Just came back from the AC service.Filled with new gas,anyway there was still 0,45kg gas in it.
And afterall.................
The cool isn't cool enough,i am not sure but maybe is the same with outside temperature.
The mechanic said that it can be the falt of ac compressor.
I was tested the ac clutch in the vag-com.
I can hear the click when testing output.
Soo don't know
Update:
Just checked the 20th channel at climatronic.
It is change the voltage level:11.4-to 11.5 when i didnt do anything
fine.
sorry if its a bit off topic,.. but where is the cabin filter on the A6 c4 ael?
TYPE-85 Coupe Quattro:clicky
2.5L GTi engineering RE2500 190hp.180lb Schrick 272 cam C A C 2.5" T304 Exhaust ITG filter
