Before charging up the air-con I started swapping o-rings, but have a problem. Item 3, compressor end nut is too big?
URS4 air-con pipe work problem
Originally posted by RichLV View PostI have a R12 system. I can measure mine if you need.
Sent from my iPhone using Tapatalk'93 Audi 100 Avant - R.I.P
'93 Audi UrS4 Avant LPG
Originally posted by RichLV View PostYou should. Since R12 is banned, both R12 and R134a hoses can carry the R134a. Get the one that suits you. Strange that they both have the same fitting radiator side...
I'll try and chase down the hose'93 Audi 100 Avant - R.I.P
Originally posted by hunker7 View PostWhat's the difference between R12 and R134a, that R12 is banned?
R12 is much more potent, it eats up the R134a system from the inside. While at the same time, R12 system can easily hold R134a, you just need to swap the AC compressor oil and the dryer can (sometimes even hoses, depends on the manufacturer). Also the refill fittings differ, but there are plenty of adapter kits floating around.
Originally posted by RichLV View PostR134a was developed in 1993 (?), as a replacement for R12. R12 was deemed too toxic and environmentally polluting. Conspiracy theorists stick to the version that it was to take out USSR/Russia from the business as R12 was mass produced there.
I'd like to think that my '92 S4 had a stickter that said something along the lines of "converted to R134A" in which case compressor should be R134A Why can't it just be easy?'93 Audi 100 Avant - R.I.P
Originally posted by hunker7 View PostI'd like to think that my '92 S4 had a sticker that said something along the lines of "converted to R134A" in which case compressor should be R134A Why can't it just be easy?
Originally posted by RichLV View Postyou just need to swap the AC compressor oil and the dryer can (sometimes even hoses, depends on the manufacturer).
