Upgrading Air con.
    Mine blows harder in recirc, I'm pretty sure this is because one of the flaps isn't closing properly so in normal mode not all the air is going through the chiller
    • Typ89
      • Apr 2015
      • 119
      I can imagine that the condenser position in a 5-pot is not ideal, maybe an extra fan would help. The compressor has more than adequate capacity unless its worn.
      If you happen to empty the system in the future, make sure to replace the orifice tube. That thing determines the cooling power of the whole system. If it gets clogged, and they do, it cools like sh*t.
      I would also try to measure the air temperature in the middle of the air box. If its cold there, the AC is fine.
      But to me, it sound like the air flaps in the heater box aren't sealing properly. All the vents in my car including the footwells blow air of the same temperature.
      • Typ89
        • Apr 2015
        • 119
        Not sure about RHD, but on a LHD car, all air goes through the evaporator, no matter where the air comes form.
        • popdemonic
          • Dec 2007
          • 1304
          • Country: Thailand
          Totally Agreed,if you're living in Thailand,This became a major problem and one of the thing I hate my UrS6.
          on summer or stuck in traffic for a longer period with stock viscous coupling,the A/C clutch will start to engage/disengage
          due to the hi pressure exceeded.it's insufficient at the idle.i decided to delete the viscous coupling and put the Spal fan
          in.the A/C clutch problem is gone.it's the good way to remedy the symptom.It's not as cold as the w124 Mercedes but yes,i can live with that.
          PS. 9/10 UrS6s have the same issue not only mine.
          one of a few I5 from Asia.
            Ah, good to know thanks. [emoji106]
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              #21
              Is this where the recirculating flap resides?
              • A80Avant
                • Sep 2005
                • 10873
                • Country: Greece
                #22
                Is it the one seen at the bottom which is operated via a vacuum pipe or the one on the top currently missing that is operated electrically?
                • mdz
                  • Jun 2012
                  • 775
                  • Country: Latvia
                  #23
                  Recirculation flap is at the bottom and operated with vacuum. The one thats missing was air flow flap IIRC.
                  • A80Avant
                    • Sep 2005
                    • 10873
                    • Country: Greece
                    #24
                    Ok, after a few tests the vacuum valve for the recirc. Wasn't working, and also the actual pump doesn't work either. So I changed the valve but there is no way to replace the pump with the air con in situ
                    • A80Avant
                      • Sep 2005
                      • 10873
                      • Country: Greece
                      #25
                      As I'm heading off for some holidays, I'll have the recirculation flap closed mechanically for now and then it may be another dash off for a fix
                      Sent from my SM-P550 using Tapatalk
                      • A80Avant
                        • Sep 2005
                        • 10873
                        • Country: Greece
                        #26
                        Geez, it vacuum pump costs about 280$
                        • Typ89
                          • Apr 2015
                          • 119
                          Maybe you can install an override switch for the radiator fan max power relay. Then you can put it on max power at any time.
                          But still, it should do that automatically if the pressure in the AC high side gets too high.
                          • A80Avant
                            • Sep 2005
                            • 10873
                            • Country: Greece
                            #28
                            I think at first I need to see how the car is with the recirc actually working...!
                            • jade
                              • Jan 2005
                              • 1811
                              #29
                              My A/C fully charged will blow -7 out of the side vent and a little warmer out of the centre
                              If they get the charging wrong less
                              RS 2 580HP
                              • jade
                                • Jan 2005
                                • 1811
                                #30
                                Also my be not a bad Idea to by pass the heater in summer as that is always hot
                                RS 2 580HP
