If you want to reduce understeer, get an RS2 FARB and a Whiteline RARB fitted...
air con decisions:
Are all rocking horses constipated then if they've all got a major backlog
Apparently they make the RS2ARBS to order so I guess they wait until they've got sufficient demand for a whole batch? They must have plenty from here if nothing else?Ex S2 owner, now running around in an A4 Avant quattro...
I know it's over 20 ordered via VAG Parts.Originally posted by dan_bAre all rocking horses constipated then if they've all got a major backlog
Apparently they make the RS2ARBS to order so I guess they wait until they've got sufficient demand for a whole batch? They must have plenty from here if nothing else?Comment
REMOVE IT
It totals about 28 kilos of excess baggage and nearly all of that weight is in front of the front axle!
If you work on your own car, you will have orgasms just how much easier the car becomes to work on (if you put it in a garage to have work, then who cares yeah!!)
Then you can use the AC button on the dash as a manual rad fan colling switch, as when ever the AC is switched on, speed 1 on the electric fan comes in, so if you're stuck in traffice, hit the AC button to keep her cool under bonnet.
Win win.
Just my tuppenceLast edited by Martynf; 27 April 2005, 10:11.Comment
Well if you guys like sitting in puddles of your own sweat against the leather, that's your own kinky look out! I'm going to persevere with getting mine working.
You could put 28Kg of ballast in the boot - say a really really big Car Stereo system
No, no, no Dan!Originally posted by dan_bWell if you guys like sitting in puddles of your own sweat against the leather, that's your own kinky look out! I'm going to persevere with getting mine working.
...to balance that lot out, you'd need 56kg in the back!Originally posted by MartynfIt totals about 28 kilos of excess baggage and nearly all of that weight is in front of the front axle!
(Unscientific but approximately right)
Lose 28kg off the front or add 56kg in the back?
Hmmm... Supposing you balance yours by adding 56kg, and I do it by losing 28kg, that's a net improvement of 84kg for me, with the same balance!
I know which one I'll be choosing!
Bye bye A/C
Dan, you sweat too easily!
__MDC__Martin Cutting
It's not better than sex, but it runs it a close second.Comment
You know mate, there's just somethings you shouldn't share!Originally posted by Skileather is good.. i love my leathers specially the heating in the mornings. BUT it has no grip to my *** cheeks what so ever! (unlike my leather pants i wear on sundays).Comment
Not quite, it doesnt use a V-belt so the pulley is different and the fittings on the back are a slightly different size. Can be fitted though, newsh has done it using some ABY pipework.Originally posted by dan_bIs the ABY Compressor the same as the 3B one?Comment
