some sort of data logging facility would probably be best
Dual plenum pics
I might well do that Doug, this is the reason why I am doing another inlet manifold. I am not too sure that the modified AAN manifold that we are using is giving particularly good flow distribution. Remember when I had that overboost situation and partially melted those sharp edges on two of the JE's? Could be that those two cylinders were running leaner?Originally posted by Doug_RS2If you are doing your own Mark, I would definitely get 5 EGT sensors mounted in your EM so you can see if you are getting equal amounts of air into each cylinder. I'll be doing that in my next EM just to be sure - don't want to melt a piston like Timucin.
Mark.Mark - ModdedComment
I haven't fully decided yet but I might use these velocity stacks as runners and have the top inch or so of the bell mouths protrude through into the plenum, like the picture at the top of this thread.
I got these from the U.S. and first saw them in this THREAD by Justin Olsen over on Motorgeek.com. The only thing is as Justin points out in his thread they are a little thin at ~1mm, but I have spoken to my Tig welding bloke and he reckons they will be no problem to weld.Attached FilesMark - ModdedComment
another, even just sitting on the flange they look 'hungry' and ready to gulp down lots of air.Attached FilesLast edited by Mark Halligan; 30 July 2005, 17:05.Mark - ModdedComment
Compared to a sectioned piece of runner from a standard IM you can see they are a lot wider at the top end.Attached FilesMark - ModdedComment
.....and slim down to the right size at the flange end. Any comments from engineers amongst us as to how these may affect the power band, would be appreciated
I have had my head off, running 2.15bar of boost on the inlet manifold, there are no visible signs of a piston being hotter than another (and I still have the sharp edges). But I know where you are coming from, much more power and I want to have the extra knowledge that they are all matched. It will also show up if an injector is not working or correclty balanced (or at least an injector or a flow problem - it won't tell you which unless you move injectors around to test that)
For the next power levels I think I am going to have 5 seperate gauges. It is easy enough to connect temp sensors to a AD converter card for a pc and you can setup warning levels etc - but the pc won't be connected all the time.
Originally posted by Mark HalliganI might well do that Doug, this is the reason why I am doing another inlet manifold. I am not too sure that the modified AAN manifold that we are using is giving particularly good flow distribution. Remember when I had that overboost situation and partially melted those sharp edges on two of the JE's? Could be that those two cylinders were running leaner?
Mark.S2,RS2,S4 WB,RS4,S4 B8,RS6 C5,RS6 C6,R8Comment
yes thats easy enough, if they all have peak hold/warning built in (although five will get expensive ) it will be even more useful, as it will save trying to watch all of them and drive at the same timeOriginally posted by Doug_RS2For the next power levels I think I am going to have 5 seperate gauges.
In the normal run of things in a well tuned engine like yours I doubt your pistons would show any signs of a flow distribution per cylinder imbalance, even if there are variances. It only showed up in mine due to a loss of boost control (loose hose to WGFV, my fault
) causing it to make crazy boost, albiet for only a few seconds.
Would it not be possible to make/build some sort of small pc type thingy to monitor five EGT's full time and data log them? I'd buy one.
Mark.Last edited by Mark Halligan; 30 July 2005, 20:56.Mark - ModdedComment
Hmm well how about a In car PC. Like a 10" screen with a small real pc somewhere in the car. If you mont it niice then you would have a niice medi system to watch movies and so forth but also you would be able to run such applications and get them up on the screen.Comment
Meep, thats what im planning on doing... The PC is already in the car and running music, sat-nav, bluetooth, wireless network (and when i sort it out, TV, Radio and GPRS Internet)
Im gonna be speaking to some other friends about making some kind of interface that can be plugged in to measure gauges etc. hopefully they'll say its not too hard and i'll be able to do it.
Only thing from your list i have that is different is that my screen is 7" touch, in the S2 dash you might squeeze in an 8" if you took the screen apart etc otherwise 7 is as big as you can go without butchering the carAnt
2011 Kawasaki Z1000
Just read thru that US post, thats some impressive work going on over there!!!
Might have to see if a friend of mine can replicate those IM's too, along with making me an EM!Ant
2011 Kawasaki Z1000
Not going to pretend that I have the greatest knowledge here, but I'd say that the wider mouth and more aggressive taper would have a stronger venturi effect, when coupled with the fairly long runner length, would be good for the lower end (more torque). Is the runner longer or about the same as stock, or whatever you've been using prior to this?Originally posted by Mark Halligan.....and slim down to the right size at the flange end. Any comments from engineers amongst us as to how these may affect the power band, would be appreciated
I'm on holiday for the next couple of weeks but popping into work on Wednesdays, I think I might ask my "fountain of knowledge" former engine building colleague about this!
__MDC__Martin Cutting
It's not better than sex, but it runs it a close second.Comment
Just a thought, if you get a flange welded around the five trumpets at a suitable place near to the mouth end, you can try different plenum shapes in an interchangeable fashion... Go CFRP and have moulded plenums for even greater flexibility!
Makes sense to me. The runners are a little longer but not by much.Originally posted by Keeper of The Kittenbut I'd say that the wider mouth and more aggressive taper would have a stronger venturi effect, when coupled with the fairly long runner length, would be good for the lower end (more torque). Is the runner longer or about the same as stock, or whatever you've been using prior to this?
I gave the first parts over to the fella that does my tig welding today, suppose I wont really know how well (or not) it works till I get it onto the motor. Its going to be a tight fit though with the smaller primary plenum as there is not a lot of room, time to move more stuff around.
does anyone drive the dahlbäck manifold?? whats the price??'94 (R)S2 Sedan
Engine:
81.4mm Forged Mahle Pistons, Pauter Rods, PKM Crankshaft V2, PKM Head V3 , PKM IM,CM Intercooler,Special Headbolts, SQ MAF,Samco Hoses, GT2Injectors, Dahlbäck Racing EM, KKK27 #9 Hotside, CM 76mm SS Exhaust, no cat
Chassis:
KW Competition, Porsche 933 Turbo Brake 322x32, 4 Caliper, Porsche GT3 Wheels 18"
Body:
RS2 Frontbumper, RS2 Rearbumper, RS2 Mirrors, RS2 MiddleTaillight, Black Hella Taillights, RS6 BixenonComment
