ABY intercooler fitting to 3b
    • 12431
    How easy is it to fit the ABY IC to a 3B? is it a straight swap?
    ta
    • 12431
    Can no1 Enlighten me....?
    • Martynf
      • 1885
      Greg according to the info I have the 3B is about 7cm shorter than the ABY, so that must mean the drivers side mounting point is in a different place to the ABY mounting point.
      What you did with the RS2 intercooler to fit your car, is the same I reckon to be done to an ABY IC to fit a 3B IC.
      Martyn
      Martyn
      www.vagparts.com
        • 12431
        Ta,
        Had someone ask about my auction you see
        • audiman
          • 4827
          Yeah Greg, just read your post about the RS2 IC mounting stuff, The 3B fits in a different way. It doesn't have the same type of fixing ie the two holes. Could be done, but why bother when you can fit the bigger RS2 one?? Nutter.
          Why is the 3B soo hard to tune compared to the ABY's, should have bought the right car in the first place. Doh!
          Tom C - www.rcmr.co.uk
          Audi UR Quattro
          Audi 100 C3 2.0 5 cyl 115ps
          Audi B5 RS4 645ps 911nm
            • 12431
            Tom,
            Do you have a pic of the fitting for the 3B? replied to the guy on ebay saying he would just need to move the mouting along ops:
            Let me know so can keep him upto date.
            ta
            • audiman
              • 4827
              I have them at home (at work now) so will post them later on, might not be until after 11pm tho. Got a pub to visit tonight
              Audi UR Quattro
              • audiman
                • 4827
                Pictures have been erased!!! Sory buddy. Cant find them anywhere!
                Proper *******.
                Audi UR Quattro
                  • 12431
                  Ok, not to worry, would be nice to see how they all differ.
                  How easy do you think it would be to fit a ABY IC onto an E Reg 10v UR Quattro. Since ive started tinkering with the engine amonsgt other things my dad has found an interest in rebuilding the engine on hiss 10V and upping the power a bit and thought could use my ABY IC to help the cooling side of things since the UR's IC is tiny.
                  • martinjs
                    • 3205
                    Greg, theres a pic in this link, halfway down page, think thats an aby cross member you can see the 2 bolt positions that aernt used, thats definately a 3b ic, 3b's mounting points are 90 deg to aby's , he must have welded a plate for it to bolt to.
                    link
                    HTH
                    martin
                    • Vagsport
                      • 533
                      Greg, short of radical, visible changes to the nose of the type 85 quattro, there is NO way the S2 IC will fit! Bearing in mind the space in the S2 is not that great (between the crank pulley and front panel / bumper) the front pulley of the type 85q is so close to the bumper, I doubt you will get even a flatter intercooler in there.
                      Siena
                        • 12431
                        Hmm, ah well.
                        Was just a thought, will have to find another way around that one i think..
                        What sort of tuning can you do on the UR's without going too mad?
