Well, I broke off the vacuum fitting on my RS2 intake. It's the one towards the front of the car that provides pressure (when the throttle is down) to the the back side of the bypass valve.
Does anyone know the part number for this part? Or is there a source for a replacement besides Audi??
Tom
Hi!,
I think I made a note of this as it was on Jimmy Pribble's e/s2 site. His RS2 manifold was provided without this part. I don't think it is listed on the EKTA. Somebody who had accesss to factory info gave him this part number: 034 133 347. Worth a shot!
Looks as though the whole S Org site is unavailable at the mo. I think it is archieved on there.
I think this is the one on the very end of the manifold which looks as though it screws in as it has a hex on it.
The Perfectionist
Thanks. Even with the site down I was able to access the info using the Wayback Machine internet archiving doohicky. I was able to confirm the number that you gave. so now I just need to find someone with the part!
That 034 133 347 number doesn't seem to exist...?? I **think** the part is either 034 133 382T (8mm) or 034 133 382AG (5mm).
Yes, I too have found the 034 133 347 number not to be valid. The two part numbers you listed do not cross referrence to the RS2. Have you ever ordered either of the two parts you listed above?? Thumbing through ETKA they don't seem to be what I'm looking for. But then again, the illustrations in ETKA have never been an accurate representation of reality. Thanks for your help.
Yep, the only thing listed is the freeze plug N 011 914 2. It bizzare that this part isn't listed anywhere. I spoke with independent my parts guy in Germany yesterday and he didn't have any luck with it either.
Originally posted by porkkis
Reroute the bypass hose to the back of the IM and use a t-piece there.
I have done a reroute on my S6, but would rather not on the RS2. I want to keep everything original if possible. Thanks for the suggestion though.
However - I have located two possible alternatives from the Audi parts bin
046 145 786 C - used as pressure point on I5 TDI engine (A6Q-96-1-29 item 20) and appears that it is threaded into the intercooler for connection of a hose.
034 145 779 D - might be too big as this is the 8mm nipple take-off point on our turbo housings where the hose to WGFV attaches
Neither are expensive so takes your pick unless some other alternative presents itself.
Thanks for the help Paul! This has been buggin me for a while.
Do we know if the 046 145 786 C is m8 thread?
The original part on the RS2 inlet manifold is M8 so maybe the 034 145 779 D might work. The WGFV hose is a larger diameter hose I think. I'll have a look tonight.
I've had my eye on part# 034 133 578 C, which I will order and then see.
I've already tried 034 133 382 T, which turned out to be the connection on the inlet for the ISV.
I'm going to have to agree with Martyn on this one. Both are listed for the ABY and RS2 manifold in ETKA but aren't not shown on the illustration. There is very good chance these are what you are looking for.
They are on back order over here so more than likely will be in the US too. As you already tried the 8mm one I ordered the 5mm in to examine. I'll post back when I have it (probably 7-10 days). If they come in correctly for what you need then I will send it on to you.
Ben
