RS2 intake vacuum fitting part number
  • twoqu
    • Sep 2003
    • 3103
    #31
    Might be worth having a word with Lupo911(Carsten from Wagner). His inlets come with a few fittings. Do you know what size thread it is?
    The small fittings that come with the Wagner appear to be M6 with a 4.5mm barb. Not sure whether he supplies all the needed fittings.
    • saltinot
      • May 2004
      • 1946
      #32
      Yes, I actually have a Wagner intake and the vacuum fitting that he supplies. unfortunately I need an M8 thread so the one from the Wagner manifold are too small thread-wise.
      It's funny that you mention that because I was thinking of asking Carsten if he could source something for me. Paging Carsten!
      I appreciate the offer to make one. If all else fails I might have to go that route.
      • twoqu
        • Sep 2003
        • 3103
        #33
        It looks like there is another size fitting on this pic which came from Carsten!
        • rs2coupe
          • Oct 2004
          • 1782
          • Home: Trinidad and Tobago Current: United States
          #34
          Oh the worries of the OEM King
          when you least expect it then it will show up exactly as you want it
          Cheers mis amigos,
          _Anton
          • martinjs
            • 3205
            Why dont you take the 2 broken bits to a machine shop, they should be able to knock one up easy enough.
            • saltinot
              • May 2004
              • 1946
              #36
              Yes, I spoke to my machinist a few months back and he said he could make one from scratch if I wanted, but the price would be around 70USD.
              I was hoping I could come up with a less expensive solution......or even a factory one.
              • martinjs
                • 3205
                Ehh?? are you serious? try a different one, coz i think he's taking the pi##
                • saltinot
                  • May 2004
                  • 1946
                  #38
                  Serious. I'll ask around.
                  • Jonas_R
                    • 3781
                    • Country: Denmark
                    #39
                    Just buy a fitting with the hose nipple of 5mm and then get it with some kinda NPT or BSP thread slightly larger then M8.
                    All the machine guy needs to do is re-thread it to M8, that should not cost more then 10-20$ if you ask nicely
                    Sleeper S2 Avant +450
                    A6 Avant 2.7t Stage 3
                    Audi S2 Coupe RS2'ed
                    • carboRS2
                      • Apr 2011
                      • 105
                      • Country: Spain
                      #40
                      I have the same problem as Saltinot.
                      I've been searching and reading several forums and came up with the image above.
                      Don't you think those nipples in the MBC could work?
                      • carboRS2
                        • Apr 2011
                        • 105
                        • Country: Spain
                        #41
                        Also check this out...
                        • saltinot
                          • May 2004
                          • 1946
                          #42
                          I'm still on the hunt for a replacement also. Not an issue yet with the motor still on the stand, but need one soon.
                          I need to start asking around though. Not much luck in the US since this is a M8 fitting.
                          • madpugger
                            • Sep 2007
                            • 1901
                            Tom remind me before le mans. I'll take one with me for you.
                            Le Mans 2012
                            Nurburgring 700
                            1995 S2 Avant
                            • Jonas_R
                              • 3781
                              • Country: Denmark
                              #44
                              Tom I have some contact for a firm in Denmark that sells all kinds fittings for cars.
                              I'm sure he has something, I could ship it with the other parts if you like?
                              But just to clarify, it needs to be M8 thread? and then what size hose does it need to fit?
                              • Thuppu
                                • 4115
                                So the thread size is M8? I'm almost sure we got some here in our local shop, I can ask alround. Fitted this to my Comp, threadsize it 1/8NPT though...
