Cold air feed?
  • stevieyid
    • Apr 2005
    • 2251
    Cold air feed?
    Just ordered my heat shield material from merlin motorsport thanks for the advice Greg, now i need to get my cold air feed sorted. I have done a search cos i thought i saw a thread abot Dougs one but i cant find anything to help. Whats the general concensus on where to fit the cold air feed? Also how to fit it? Thanks for your help
  • Bibby
    • Aug 2004
    • 1043
    If you have the aux rad in place, and an aircon pump, it's a ball ache to get anything of a decent size hose in there.
    Removing the aux rad really frees up a bit of room, as does removing the aircon, although that's a bit more drastic.
    acidtrax
    • stevieyid
      • Apr 2005
      • 2251
      i have a rs2 bumper fitted and i was thinking of cutting a hole in the corner mesh insert, although i have not had a look yet. Would that give sufficient flow?
      • s2_southwest
        • Oct 2004
        • 823
        while i had the front bumper off my s2 i saw that there is quite a bit of room if you were to atatch a pipe to the boost pipe exiting the intercooler and running the pipe up so the cold air would almost blow under the filter...
        Pearl white 91-S2-3B K&N cone air filter - Home made induction pipe work - 18" RS4 replica alloys - Yokohama Parada Spec 2 rubber - Colour coded body work - Bilstein/H&R suspension - s/s 3in turbo back Longlife exhaust - SFS water hoses - Samco boost hoses - RS2 FARB - RS2 eyeballs - Squeaky interior trim & 2 bar!
        • sorens2
          • 241
          • Country: Denmark
          Powerblanket
          This is my solution.
          Søren S2
          Audi RS4 LO550
          BTG 8:08
          www.fredslunds.dk
          • sorens2
            • 241
            • Country: Denmark
            From the front.
            Cold air via headlight opening.
            Audi RS4 LO550
            BTG 8:08
            www.fredslunds.dk
            • stevieyid
              • Apr 2005
              • 2251
              i got my filter pointing towards the headlight but i dont think it gets sufficient air flow.
              • Ski
                • 2591
                same here.
                Ive made something similar to Soern's setup but not as efficient. need better material.
                ABY Coupe
                • s2driveruk
                  • 12696
                  what material are you using Soern?
                  1992 3b S2 Coupe
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    what air filters is ever one using? thing about doing it my self so i will be taking notes
                    Chef
                    • s2driveruk
                      • 12696
                      K&N here....
                      1992 3b S2 Coupe
                      • sorens2
                        • 241
                        • Country: Denmark
                        HKS Superflow
                        This is welding blanket.
                        Got it at work.
                        It will cope with 1000 deg. cel.
                        Søren S2
                        Audi RS4 LO550
                        BTG 8:08
                        www.fredslunds.dk
                        • ericd
                          • Nov 2003
                          • 1240
                          Quikshift racing filter with 2 old hoover/hose cold air feeds fed from the front over and under the filter....
                          • ericd
                            • Nov 2003
                            • 1240
                            another pic showing the hose/s from above
                            • terrybullwon
                              • Mar 2006
                              • 8782
                              does this cause any problems?
                              Chef
