I was planning on replacing the standard airbox and was wondering if a BMC Carbon jobbie would work well. I'd like to make up/buy a heatshield like the one that is included in the Dahlback kit. Does anyone use one of these just now and is it any good?
Cone v Airbox
The pic show something very similar to the heatshield included with the dahlback kit , I think I may have very rough dimensions somewhere , I'll have a look
tn_dscf0292.jpgComment
here it is very rough as I mentioned
. the tab piece is bent and should have a hole through it which fits into the original screw fixing point of the airbox assemby down beside the wg and turbo.
tn_HEATSHIELD.jpgComment
re
have a bmc cylinder carbon box on mine and its great,no probs with heat-soak and sounds lush (race only
Cheers mate, I'm away back offshore next week, so I might try making up a stainless one whilst no one is looking
. I've emailed Dahlback about purchasing an induction kit minus K&N filter, so going to see if they come back with anything. I'll definately need to source the 180 degree bend from somewhere, as we don't have anything of that diameter in stainless aboard! A friend has a BMC on his GTI-6 rallye and he seems pleased enough with it, so I imagine it would be a decent enough thing.
I think it'll still cost you around £130-150 for the h/shield and the pipe bend assembly, alloy or silicon bend are readily available , many threads in the forum showing different variations on a theme, don't think using s/s would give you any great advantage over the cheaper alloy/intercooler pipes on the bay etcCheers mate, I'm away back offshore next week, so I might try making up a stainless one whilst no one is looking
. I've emailed Dahlback about purchasing an induction kit minus K&N filter, so going to see if they come back with anything. I'll definately need to source the 180 degree bend from somewhere, as we don't have anything of that diameter in stainless aboard! A friend has a BMC on his GTI-6 rallye and he seems pleased enough with it, so I imagine it would be a decent enough thing.Comment
Past: S2 ABY coupe RS2 spec with lots of mods, S4 B5 saloon, RS6 C5 saloon, S8 D2 FL, RS4 B7 saloon, S4 B6 avant
Present: S4 B8 avant, MRC Stage 2Comment
We've tried using both open-air kits, and stock airboxes and aby and also RS2, the RS2 is the best one, even with the open-air kits included, on a really really cold day, with a medium temperatured engine, I would GUESS that the open-air kit would perform about the same as an RS2 airbox.
However we modify our airboxes to an RTM version
This is how it looks.
ABY:
RTM
erixon is the engineer of this amazing airbox
And of course. After this mod, this box outperforms the RS2 ones. When we finish rebuilding erixons engine, we will take the car to the drag strip and see how fast the box can go (rs2 turbo and em + RTM mods)2004 9-5 aero
2009 Subaru Legacy Diesel
1994 Toyota Supra Eurospec 6-spd LHD
3-4 Audis in parts
To swap them you will also need the plastic behind the headlight since the 3B has a slot and the ABY box has a round inletGreg
Anyone know what the best mod is with an S6/S4 with all that extra room we have.
I want to have a nice sound (cone) but I want to have the best gains (k&n in the airbox by all accounts), any ideas?UrS6 - Homefry, Bailey DV, PiperX filter, Samco hoses, H&R springs, 3" D/P back zorst, 270bhp and 260ftlb :rock:
Triumph Daytona 955i - mmmmmm :fire:
80 dag dag :driving:
