Boost pipe. Aluminium or not
  • Boost pipe. Aluminium or not
    Just wondering what material is the big black boost pipe from the intercooler to the Intake manifold made of?
    My stock pipe is painted black, but the small schratches it got with shiny metal underneath does not seem to corrode.
    So was wondering if it might be aluminium?
    Anyone got an idea?
    try with a magnet
    RS2 Black - stock 315 HP
    RS2 RS blau - stock 315 HP
    Sport Quattro - 1005 HP
    High Octane website
      aluminium is not magnetic, right?
      Great idea, thanks
        As is Stainless
        High Octane website
          There are some welded on brackets IIRC? Look at the size of the welds - if they are small it is probably steel, aluminium welds are a lot bigger.
          Weight is also a good thing to check! You will know straight away when you pick up this boost pipe.
          __MDC__
          Martin Cutting
            Welds on the brackets seem pretty big, dont know about the wieght, its not extremely heavy, but not lightweight either.
              Its steel,
              I fit a bov on my last RS2 in that pipe.
              Rob
              Rob..
              87 UR 20v ABY
              97 S6 Avant
                hmm, i think mine is alu, its not magnetic, so now its polished high gloss, hope it does not corrode then if it really steel
                  didnt they do them in plastic aswell
                  94 s2 avant
                  aoc member 1116
                    I thought the 3B one was steel and the ABY was plastic.
                      my 3b one at home that is black is steel,,, but i pimped a polished one on
                      Chef
                        Both of mine are steel, ABY in UR, ADU in RS.
                        Rob..
                        87 UR 20v ABY
                        97 S6 Avant
                          will let you know i mine starts to corrode, i really hope not, then I wasted a couple of hours polishing and need to paint agian
                            Originally posted by coupegt
                            will let you know i mine starts to corrode, i really hope not, then I wasted a couple of hours polishing and need to paint again
                            Not really, you could always clear laquer it
                            • #15
                              Any one got a picture of this pipe? Or a schematic?
                              I need a replacement, as this is where my boost leak is coming from...
                              (I think)
                              Sorry to hijack
                              T
