Exhaust 2.5" 0r 3"
  • desmo888
    • Oct 2003
    • 390
    Originally posted by blown_vr6
    The first few inches after the turbine housing are the most important - you could go 3" downpipe and 2.5 or 2.75 all the way back.
    Pete.
    This is also what I understand to be true. The dp sets up the speed of the gases exiting, after that it should be as free of restrictions as possible.
    Be aware, many folks in "the business" think they know more than they actually do. I guess that could work both ways but from my rudimentary understanding of fluid flow, from the dp back, bigger is better.
    Dave K.
    USA
    1991 e//S2 (home built S2 - the only way to get one in USA!)
    2001 S4
    • 1975DCS
      • Sep 2006
      • 258
      Are there any "cheap" 3 inch (or 3.5 inch) exhaust ready available for an S2 Coupe? Or is everything limited or custom made? Previously I had cars fitted with Simons and they were simple steel, cheap and silent (I like that "stealth"), trouble is the 2.5 is not truly 2.5 in the dampers...
      • Fat Audi 80
        • 10547
        I thought 3" was tricky over the rear axle on a coupe?
        Cheers,
        Steve
        The Perfectionist
        • K7ERG
          • 1711
          I went 3" results
          Standard power 230bhp not sure on torque.
          Power run 265bhp at 6500rpm @0.9bar and 250lb/ft at 4000rpm. Not bad as it is 15years old car which has covered 188000miles and standard apart from cone filter and 3" exhaust.
          Revs better, smoother delivery and more power. If your thinking of more power in the future go 3" that way you buy one exhaust instead of 2.
          Craig
          Audi A6 AEL 5cyl Quattro breaking.
          Audi A5 3.0tdi Quattro Stage 2
          07947385043
            Cheers,
            Steve
            Yes what they do is reduce it to 2.75 over the rear axle.
            3" over the rear axle is possible but normally it knocks on every bump.
            • Audi_CQ
              • 940
              • Country: Norway
              #21
              3" is no problem and it doesn't knock on every bump It just take some time to get it right.
              • BRY
                • 3755
                #22
                3" is no problem on an Avant
                  It does on an S2 as it catches on the rear diff.
                  2.75 is a much more elegant solution. It's not a issue either as the exhaust gas will have cooled enoughed by then that it doesn't become a bottleneck.
                  • 1975DCS
                    • Sep 2006
                    • 258
                    So that is why side exhausts are so popular again...
                    Group A style all over again!
                    • s2driveruk
                      • 12696
                      Longlife fitted a 2x2.5inch cat back on my 3b and said it would be fine to about 300bhp infact they said the most restrictive thing on the stock S2 exhaust was the Y at the bottom of the d/pipe and that was it.......
                      1992 3b S2 Coupe
                      • Corey
                        Banned
                        • Sep 2003
                        • 2793
                        Depends whose system and how they fit it
                        Never had an issue with a 3" system it is just matter of time and patience
                        Corey
                        01636 822288
                        • blown_vr6
                          • Apr 2005
                          • 406
                          Can they not ovalise the section where it goes over the rear axle Corey?
                          'If you ain't broke it you ain't trying hard enough'
                          Oh sh*t i broke it
                          94 S2 Homefried Decatted Slipperwagon,QRS Top Mounts,Ally Subframe bushes,Poly ARB & Wishbone bushes,RS2 ARB's,Koni & H&R's,Cupra Brembo's and 312mm discs
                          • Corey
                            Banned
                            • Sep 2003
                            • 2793
                            There's no need, with the system we use it comes with V-Band clamps so once it is in place and aligned correctly the joints don't move and by using the hangers with the chains in them you end up with a no knock system.
                            Corey
                            01636 822288
                            • S2_Dave
                              • Aug 2005
                              • 456
                              Corey fitted my 3" exhaust and I've not had a single knock.
                              David
                              '91 3B S2 Coupe
                              • s2driveruk
                                • 12696
                                i've got those chain rubbers and they are a bu**er to get on but once they are the system doesn't move, they are fantastic
                                1992 3b S2 Coupe
