Hi again
Ok looking at the engine towards the windscreen top of the engine under intake manifold at the back...
three pipes reading from left to right
First pipe comes out goes left to a T piece and carries on to the front of the turbo thats fine. At the T piece there is a 3inch piece of pipe with a bolt in it.
Second pipe 3 inch piece of pipe no blockage and sucks when the engin is running.
Third pipe comes out goes left to a pinkish pipe and goes in to the bulk head.
Bottom of the fuel return Fuel pressure regulator i think, rubber pipe 14 inches long but hanging in mid air??
Found the ecu pipe not connected to anything?
I have the diagram but am confussed
Where on the bulk head does the ecu pipe go through and is it easy to get to.
I have connected up a series of pipes to various combinations but have only made the car stop idling or no boost.
If i put back to the way it is just now i get cough and spluttering up to 3000rpm but solid boost past this.
Checked the oil and levels fine but oil pressure not going past 3.5 bar.
Thanks for all the help last night sorry to be a pain But can you help??
The ECU pipe goes behind or under the battery and is quite difficult to get to. Mine is not actually in the original place because of this so I can't tell you exactly
If you remove the glove box you'll find the ECU up behind the heater unit.
