Airbox
  • Dan_s2_coupe
    • Aug 2006
    • 482
    Airbox
    When i bought my S2 it had a big K&N fitted sounded really nice with induction noisy and wastegate chatter
    But reading some threads people said airboxs were better so i tryed it
    and OMG it makes a lot of differents at cruising speed so much better pull
    But i really miss my noise that roar from the filter then the wastegate and recerculating dumpvalve that came back through the filter now its gone
    any 1 no how i can fix this i want the sound and the ulling power dunno wot 2 do HELP!!!
    • 12431
    if you get an RS2 airbox and a decent panel filter you will get some of the induction noise back. also if you make a heat shield and air ducting for the cone filter it will work better too
    • YELL MAN
      • Dec 2005
      • 541
      • Country: Shetland Islands
      How much is a RS2 airbox for a matter of intrest?
      1994 Indigo Blue S2 coupe
      1994 80 Avant 1.9 TDI
      2005 Yamaha Fazer 1000
      1953 AJS Model 18S
      • Ski
        • 2591
        new? prob 500 inc all fittings.
        ABY Coupe
        • YELL MAN
          • Dec 2005
          • 541
          £500 holy SH*T
          1953 AJS Model 18S
          • andyg plym
            • Nov 2006
            • 4646
            re
            ive been running round with no air filter in my box for ages now, if you look indide the box near the top there is already a small filter in there. Crued but effective....
            • rotoryboy
              • May 2004
              • 3281
              Are you mad?
              Mark
              Race Clio RS197
              S2 Coupe ABY (Green) - RIP
              S2 Coupe ABY (Blue) - Sold
                Originally posted by rotoryboy
                Are you mad?
                Barking, woof woof
                • blown_vr6
                  • Apr 2005
                  • 406
                  That doesnt filter out small particulates though does it - its only a mesh and not a very fine one at that...
                  Your daft mate....
                  'If you ain't broke it you ain't trying hard enough'
                  Oh sh*t i broke it
                  94 S2 Homefried Decatted Slipperwagon,QRS Top Mounts,Ally Subframe bushes,Poly ARB & Wishbone bushes,RS2 ARB's,Koni & H&R's,Cupra Brembo's and 312mm discs
                  • HPmuirt
                    S2Forum April Fool
                    • Apr 2005
                    • 3014
                    Indeed, I went from a stock S2 to an RS2 airbox, but did not have the RS2 air duct panel which the trumpet fits through, so I removed the trumpet and had an open RS2 airbox. There was a significant increase in both induction noise and WG chatter.
                    When I then fitted the trumpet and the airduct panel it reduced both to a nice level...louder than stock S2 but not chav loud
                    RS2 airboxes tend to go for around £100 on German ebay. Took me about 6 months to get one though as they are not the most common of parts.
                    Cheers n
                    Si
                    Subtle mods here and there
                    2011 A5 3.0 TDi - Lava Grey
