Exhaust note with 7A Ex Cam?
    My exhaust note seems to have changed since fitting the 7A ex cam, a little louder and fruitier I'd say, bit more of a burble.. Well thats the best description I can come up with.. Anyone else noticed this when fitting the 7A cam?
  • dkw_dude
    • 555
    • Country: Norway
    A little o.t. but did you notice any difference after installing the cam? (I have a 7A ex cam on the shelf myself, RS2 setup on the car)
    Cheers and Merry Christmas
    Leif-Helge
    Leif-Helge
    -91 S2 VEMS and Comp Turbo
    -12 B** 530XD Touring "S2 parts transporter, and daily driver"
      Leif-Helge
      Difficult to say as the head was changed at the same time but I'd say it felt stronger and seems to rev out a bit better, the stock downpipe is now the bottleneck.
      • dkw_dude
        • 555
        • Country: Norway
        Ok thanks, will post reply regarding ex note when I have installed my 7A ex cam (may take a while as I am moving from a flat to a house, so I will have to spend less time on cars ) .
        I have 3" from turbo so it should flow nicely.
        Leif-Helge
        • dan_b
          • Sep 2003
          • 3670
          Newsh, did you get a re-map at MRC with the 7A going in?
          I was surprised at how different the engine/ exhaust note was with your car vs. mine (whoops, Robatron's!) with the RS2 turbo/ manifold, was a lower overall tone to the engine vs. the k24, so I can quite believe that the different cam would change the sound a bit.
          How's it driving now?
          I'm still mulling over getting mine re-mapped, maybe I should drop some cams in at the same time. Oh dear, the Dark Side never leaves does it!
            Dan_b, yes I'ts been remapped for the Cam, RS2 airbox, BMC filter and bearing in mind the steel rods Its running enough boost to make the injector O rings leak
            And it fair s
            Next up is a 3" exhaust, Mihnea says thats my restriction now.
            • K7ERG
              • 1711
              I removed the downpipe and system. replaced with 3" and it made a huge difference. 35bhp and 40lb/ft. on standard boost.
              Audi A6 AEL 5cyl Quattro breaking.
              Audi A5 3.0tdi Quattro Stage 2
              07947385043
                Wow! Better get that 3" system ordered then!
                • K7ERG
                  • 1711
                  That was saying the engine was sitting on standard power before on normal unleaded.
                  Just a cold air feed and cone filter with exhaust. Engine has covered 190000+miles now.
                  265bhp cant remember the torque.
                  Dastek rolling road which was used.
                  Mind its a AAN engine.
                  3" from turbo no cars and one box. Mandrel bends.
                  07947385043
                  • Acidburn
                    • 13459
                    And it fair s
                    Can you get uprated injector O rings?
                    • K7ERG
                      • 1711
                      I would just replace with new o-rings.
                      What boost is it running?
                      craig
                      07947385043
                      • Acidburn
                        • 13459
                        From what i've heard of cars running the 7a exhaust cam is around the 1500-2000 mark you get a sort of off beat thrum to the sound/note from the engine, might just be on big boost cars tho. Sounds nice.
                          Yeah, it sounds nice, and yes I just fitted new O-rings.
                          • Acidburn
                            • 13459
                            What sort of power you running now?
                              I would guess around 360-370?
