What EGT ( pre-turbo ) temperature yours measure with 7A cams using original timing?
Egt in exhuast
I have constant measurement in each runner. What i can see from my logs is that cyl nr 4 is almost always the hottest one during hard pulls. Could be a measurement fault.
Here is a picture from my log file, EGT 1 is cyl 1 and so on. Sensors sits in the middle of the runners.
Originally posted by s0_bigI have constant measurement in each runner. What i can see from my logs is that cyl nr 4 is almost always the hottest one during hard pulls. Could be a measurement fault.
My point about cyl3 being the hottest was from my mechanic having suggested in the past that as it sits in the middle of the 5 cylindes on the block it seems to be the one needing rebore the earliest. I
May be wrong of course
- 1 like
