Thanks error404 for the offer. Roose should be able to do me a hose that will fit, they can do the same pipe with 62, 70,76 inlet. fingers crossed. Trust me to end up with a dodgy turbo
Help!! fitting silicone hose
They made a bespoke one for me at pretty much the same price as the standard item. I have a kkk26/27 with a wider compressor inlet. The only problem was that they used the original tooling and added a wider section at the compressor end. This meant that there was a restriction just before the turbo entry which wasn't very good for flow into the turbo.91 Modded 3B
14 A6 Avant Black Edition
