Reverse intake manifold made by BST turbo
  • Reverse intake manifold made by BST turbo
    I want to buy a reverse intake manifold from BST turbo. Here is the link http://www.bst-turbo.de/home/ansaugb...s2-rs2-s4-200/
    Is someone that used this intake ? Any opinions? Better alternative?
    Thanks!
    Audi S4 2.2T 5 spd 1992 for parts
    AUDI A4 1.9TDI daily use
    Audi 80 Quattro 2.0 16V (ACE) aka Competition
    afterthought uses one on his Urq, I'm sure he'd have an opinion to offer.
    Find me on Instagram @pry4sno
    2010 Golf Sportwagen TDI /// Wifey Mobile
      I think that for the money it is a really nice intake . To install it in the B2 I had to do a few things custom. Design seems quality.
      It clears the hood with no issue which is nice .
      The radiator fits well with no clearance issues . I am running Vacuum boost brakes and it comes with a large supplies port for that and the small ones you need.
      •The throttle cable that was provided with it needed to be changed to a “hook” on the end
      •the intake runners are very short and main plenum or whatever fits very close to the head, so I had to be careful with injector selection and had to modify the fuel rail on the bottom to allow for the injectors to sit under the rail as they cannot be rotated to where the plugs face the head. Depending on the type of rail and or extrusion it is cut from this might not be an issue .
      This is what I was referring to with the injectors. The amount of space between fuel rail and head is absolute minimal so with the right fuel rail and injectors it shouldn’t be a problem . I just had to modify what I already had .
        Thanks for replys! Can I use a AAN fuel rail? Is the angle of injectors right ?
          Boy I don’t know for sure about the fuel rail.
          If anyone recognizes this one pictured on their site , I don’t know if this is AAN , ABY or what
            Can you let us know what modification you have done to the pas pump in order to fit the intake?
              I know someone selling one... if you want it.... would be cheaper than new and is in great shape...
                You got Pm!
                  as have you...
                    Here you go....
                    https://www.s2forum.com/forum/member...-plenum-intake
                      Do you have anypics with the inside of the intake manifold ? Has this intake ' trumpets' ?
                        AAN fuel rail it won t fit as it is. I try to figure it out a solution using EV14 injectors.
                          You mean it won’t fit because the tabs that the Allen bolts go through are not aligned?
                            I will post tomorrow some pics . In small talk not the tabs are ok and not the banjo bolt with pressure from fuel filter .
                            • #15
                              The fuel rail in the picture with intake manifold installed is a stock fuel rail from ABy or ADU engine.
                              I try to use a AAN unit ,slightly modified or a custom one.
