Watched that many many times. My word revs rise fast and also seems to pull pretty damned hard too. There is a bit where the last you see of the rev counter is it steady at 7000rpm and driver plants throttle and presumably the car accelerates so hard the camera moves and you stop seeing the rev counter. 8000+rpm?!?
BMW throttle bodies could be fitted. Some hassle gives that it is difficult to get the vacuum/pressure thing.
I had a set if 45mm toyota throtlles on my 2.0 NM 20V engine. It sounded great, but didnt perform as good as it sounded. Not worth all the effort unfortunately. Lots of things have to be modified to fit. Custom radiator as trumpets were hitting original radiator. Remove brake booster for trumpets. Move the ps pump etc.
