I took a punt on one of these.....
https://cgi.ebay.co.uk/ws/eBayISAPI....=1101514998024
Out of all the RS2 EM knock off's I've seen these are by far the best, okay it's not perfect, ie not all the flats for the nuts have been machined and the collector and waste gate castings could do with do with a little cleaning up with a dia grinder, hell even even a Dremel would do or an abrasive bit in a drill as there's not much that needs to be done, it could be used as is. However the runners are nice and clean, it fit's properly and the internal casting is an accurate copy of the genuine unit. I'm going to machine the flats on a friends mill and give it a quick go over inside with a dia grinder and be very happy with it For £80 delivered from the USA!
