I menntioned this to people at Combe and the RR day in October. Only just had a chance to take a picture of the airbox as I was hunting a boost leak on the low pressure side after buying one of AndyP's boost test kits.
Because I'm tight and couldn't be botheretd to fork out over £200 for an RS2 airbox and because I really didn't like the noise of a cone filter, I decided to modify a standard S2 ABY airbox to get rid of the beautifully sculpted bell-mouthed noise reducing trumpet on the front. This was a 'suck it and see' modification and I have kept it for the last 6 months as I really quite liked it
I have no idea if it's improved flow but a strong performance on the rollers last October supports the idea that it hasn't done any harm. The inlet hole is now about 3" x 4" instead of 2" diameter giving over 3 times the inlet area. There are of course arguements about turbulence but the air turns through 180deg anyway so I believe that the additional turbulence caused by the rough edges is minimal compared to the change in flow direction.
The car now makes a lovely purr as opposed to being silent or the harsher, more mechanical sound of the cone filter, and off boost it sounds like a mk.2 Golf that I used to own, also with a heavily modified airbox.
Overall then, more inlet area and a nicer (IMHO) noise, all for the price of a secondhand air box and an hour's work. Job done !
