Hey folks, can anyone help?
Trying to prepare to remove the engine and i am unbolting the downpipe and the wastegate flexi.
However, what is the best way to get to and remove the 17mm bolt on the underside of the downpipe flange…the one nearest to the block/manifold? I remember this being a sod before but memory failure has kicked in.
Any tips welcome…thanks!
with a ratchet instead as the bolts for the flexi are rounding nicely and i will deal with it once the engine is out.
We just used a normal spanner or what its called, filed it down a bit and bent it with heat.
