exhaust gasket
  • nw66
    • Apr 2023
    • 135
    exhaust gasket
    anyone know where to get exhaust to turbo gasket cant find one? metal one..
    93 ABY S2
  • K Simmonds
    • Dec 2007
    • 7633
    That isn't a part I've need to find for some time, last I got one it was when I fitted the RS2 Turbo to my 3B. I got that along a down pipe gasket with all the new nuts required for mounting a turbo from TPS, so genuine Audi parts and they weren't expensive.. The only thing that was potentially costly were the wastegate gaskets, they were sill money and I had some aftermarket ones that did the job just fine...
    However that was nearly 10 years ago so I have no idea if they still stock them, I could call them to find out for you.
    Failing that I may have a spare or two knocking about, would have to check my gaskets draw,
    You could make your own out of some 0.8mm copper sheet, but that would be a last resort.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • tango123
      • May 2017
      • 892
      https://www.ebay.co.uk/itm/225483454...Bk9SR_bgmrbhYg
      • nw66
        • Apr 2023
        • 135
        Cool thanks both.. did see that on ebay but wasn't sure if was the correct size.. ta very much..
        93 ABY S2
        • K Simmonds
          • Dec 2007
          • 7633
          Have checked my spares draw and I only have one new genuine Audi one and two used ones... So unfortunately I can't help you out as I like to enough parts in stock to change a turbo if I'm in a hurry... If you're really stuck I can try ordering the parts from TPS if they still stock them. I like to replace all the fixings and gaskets with new parts if possible.
          Sent from my SM-A115F using Tapatalk
          1994 MTM RS2.
          2000 B5 TQS.
          • nw66
            • Apr 2023
            • 135
            Thanks maté yeah agreed always use new gaskets.. I've ordered one from highland Quattro hopefully that will do the trick..
            93 ABY S2
