STR Audi 20V exhaust manifold
  • Bram
    • Aug 2006
    • 2582
    OK, I recieved the thing today. It comes with a pair of gloves! What the.....?!
    They sprayed it with some grey paint, but I have no idea if it has a special function or something like that.
  • Bram
    • Aug 2006
    • 2582
    another view
    • Bram
      • Aug 2006
      • 2582
      view 3
      • Bram
        • Aug 2006
        • 2582
        view 4
        • Bram
          • Aug 2006
          • 2582
          view ......
          • Bram
            • Aug 2006
            • 2582
            quite smooth!
            • Bram
              • Aug 2006
              • 2582
              look! the neighbours!
              • Bram
                • Aug 2006
                • 2582
                hole
                • Bram
                  • Aug 2006
                  • 2582
                  another hole
                  • Bram
                    • Aug 2006
                    • 2582
                    the last one for now
                    • Bram
                      • Aug 2006
                      • 2582
                      It's a bit better finishing than the XS-Power manifold I would say. I had that one before, so can compare it.
                      I hope to start building very soon, as I have also ordered injectors, etc.
                      Just need to re-calibrate my 250Kpa MAP sensor to 300..... Anyone has an address for that?
                      • AndyP
                        • 6049
                        • kwlw
                          • Sep 2004
                          • 1025
                          • Country: Lithuania
                          Where are studs?
                          Hi,
                          Very interesting manifold , however:
                          Where are studs for WG and turbo mounting? From what I see, there's no thread for them in the holes. WTF? Are you going to bolt stuff by bolts and nuts?
                          Also, it seems, that this manifold has no collector for all cylinders to come into one place. What will happen to the exaust valves in cylinders 1 and 5. Are you aware of this? I mean are there success stories of running this manifold, or you will be the guinea pig?
                          Sau
                          • Bram
                            • Aug 2006
                            • 2582
                            Originally posted by AndyP
                            OK, thanks! 80 Euro is not too bad
                            • Bram
                              • Aug 2006
                              • 2582
                              Originally posted by kwlw
                              Hi,
                              Sau
                              I have ordered the studs at 034 Motorsport. The holes in the STR manifold at the WG and turbo have threads as normal manifolds have. It's hard to see from the pictures, I admit.
                              Concerning the collector..... 034 Motorsport had exactly the same design of manifold and that one flows over 500 HP. Too bad that the 034 one had some issues with the material they used.
                              So in a sense I will be the guinea pig yes
                              Let's hope for the best. I will start with a RS2 turbo setup first to test the manifold
