well i managed to answer my own question.....i bought a RS2 maf myself and i can say there is no difference between a S2 one and i didnt even have to modify my aby airbox to fit! the diameter is the same so how does the RS2 maf flow more?
Alan at vagparts done me a great offer, £141 delivered to my door!
1995 B4 Audi 80 S2 avant 267bhp and 326lbft *sold*
Look at the shields on the RS2 compared to the stock. The RS2 shield is less of a restriction and therefore allows quicker air flow.
So is the flow the only difference between stock and RS2 MAF? I have now used the RS2 MAF for a week and seems to be some difference in behavior and AFR(lambda values).
The car feels more responsive and efficient. On idle the lambda value is now 1.12-1.20. With the stock MAF it was 1.00-1.01.
On light revs the mix stays quite lean and only on high boost it riches out. On full throttle and boost the lambda is 0.88-0.89. Before it was 0.86 and the mix was whole time on the rich side on light throttle and boost.
Does these kind MAF's wane bit by bit or does they only die inctancly?
change the MAF and re install your original one
i did something similar around 3 months ago testing 2 diferent 3B Mafs and with the not original one my AFR values were leaner,just as you says
i have heard that all or some ECU setups needs to be desinged for the diiferents Mafs ...
RED Mitsubishi Lancer Evolution VI TME nº 16 of 250 BLACK Mitsubishi Lancer Evolution VI TME nº 189 of 250
Internally the RS2 MAF and AAN/S2 MAFs are the same. Looking from the inlet end, you can see the difference in restriction to air flow (AAN/S2 on the left, RS2 on the right). On that basis, I have no doubt that the better response that you *think* you are experiencing is real.
More MAF info HERE (note link to Paul N's MAF info in there)
Below is how the RS2 MAF fits to the airbox, both S2 & RS2. You must rotate the MAF as seen in the photo and then mount your bolts. It's still a very tight fit.
Yes, I'm known about the visible differences, but the difference in the mixture before and after is quite big especially on idle, so I wonder if there are also some other differenceses between theese MAF's..? The reason the efficient is better is propably because the mixture is leaner.
Do you have any opinion about this question? I was thinking if my old AAN MAF was worned a bit when we made the remap... I soon get another AAN MAF for testing, then we see how it works.
That means one of the MAF's is off calibration/broken.
I have personally swapped two working MAF's on my car and logged AFR, it's exactly the same.
They do slowly get less sensitive.
Is the RS2 MAF new? Or is it used?
Either way, when fitting two different new/lightly used MAF's I had no change in AFR. And I wasn't looking only on the display of the controller. I actually logged the exact same pull on the exact same piece of road from exact the same RPM's.
No difference.
It's used. If you Dmitri remap a car, can you tell without comparsion if the MAF has seen better days?
