50mm was fine on my car, that was an HKS replica. I stripped it down when it arrived, looked ok inside, put it back together and it never caused any problems. But if you can afford it then go for a pukka one, but no less than 50mm IMO.
stock one is only 38mm, and if you use a decent manifold, are running 500+bhp then its gonna struggle to keep the boost down, esp. at high revs.
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nm
Is there any specific reason that you have bound all of your EM pipework in heat protective tape? Were you melting other components or are you trying to stop the EM cracking or some other genious plan?
Cheers n
Si
95 ABY S2 Coupe - Ragusa Green Subtle mods here and there
2011 A5 3.0 TDi - Lava Grey With every option available (except a towball)
Cheers n
Si
To help prevent the exhaust gas heat radiating out through the manifold. The hotter the gas the more kinetic energy it has and it will flow at a greater velocity.
Yep thats about it, mind you I expect the heat will kill the EM at some point in the future even though its well braced.
Originally posted by terrybullwon
Any more pics, of your set up there mark?
I still need to finish off a few things like general tidying up of hose/cables runs and bodges, fit a new gearbox, and get it mapped. I'll post some more pics when its done and happy with it, hopefully soon
