New version of IM on my conversion
  • linelis
    • May 2007
    • 28
    • Country: Lithuania
    Hello all,
    as my conversion is moving step by step - there is one step of my "artwork". IM conversion to fit S2 type car with AC.
    More picures will come.
    L.
  • linelis
    • May 2007
    • 28
    More angles...
    • linelis
      • May 2007
      • 28
      and another...
        • 12431
        Did it take you long to convert it all and measure up?
        • linelis
          • May 2007
          • 28
          Well, dreaming, measuring and cutting took me about 3 evenings. It was a big problem for me finding elbow, so went to tubular decision.
          Then went to welder and we joined the tubular neck to IM on the 3 "pins" (welding wire). Came back to measure on the car. Trying to adjust, everything falls appart. Lost 1 day. (#4)
          New measure and final welding took me some 5 hours with riding. It was then day 5.
          Here it is on the car (mobile photo).
            • 12431
            Looks like a good fit, have you changed the throttle cable?
            • Azman
              • Sep 2005
              • 3205
              Looks very good matey, adjustments for the pas???
              Dark Grey Avant
              RS2 FARB
              Alloy Subframe Bushes
              • linelis
                • May 2007
                • 28
                Hello Greg_S,
                I left original cable, but joined with some xtra cm cable. Not the version I like, but it enables me to start the engine. That's what I did this night. On 3 cylinders . Got new spark plugs, it may change for good.
                Besides oil cooler leaking ....
                L.
                • linelis
                  • May 2007
                  • 28
                  I broke only 2 crossbars. 1'st and 2'd cylinders. Left others in place. There are plenty of space to last cylinders around, so left original.
                  L.
                  • linelis
                    • May 2007
                    • 28
                    After 1'st day driving...
                    • linelis
                      • May 2007
                      • 28
                      and more
                      • linelis
                        • May 2007
                        • 28
                        and last one
                        • s2_bo
                          • Oct 2005
                          • 6067
                          How come your IC is so high up? Have you mounted something where it used to be?
                          91 S2 coupé - RIP
                          98 S8 - Luxury barge
                          • kwlw
                            • Sep 2004
                            • 1025
                            Sau
                            • donce
                              • Aug 2005
                              • 127
                              its very nice done,and idea is great.but what about IM flow? stock aan IM flows very well,but when there will be different air direction, imho some cylinders will flow worse... well anyway,its just an opinion.
                              nice job
