7a to 2.8 MAF upgrade, need help!
  • psiconauta911
    • Oct 2007
    • 613
    • Country: Portugal
    Fellow members in the S2 Forum I need help.
    Here in Portugal there aren´t any 2.8MAF second-Hand and the dealer price is out of my range.
    Anyone can get me one?
    Preferably from Europe!
    Thank you all in advance for any help you can give me.
    Pedro
  • BRY
    • 3755
    Click this
      try ebay they come up pretty regularly. Interested to see how you get on with this mod, i;ve not bothered on my 7A(s) but might if you notice much improvment in throttle response etc
      Good luck
      EDIT: D'oh!
      • mcandmar
        • Apr 2004
        • 5118
        I "think" there is two different 2.8 v6 MAFs.
        91CQ20v - Gone to a new home
        93UR-S4 - The Magic Carpet
        94S2Bus - The Emerald Express
        • Cullam3n
          • Aug 2007
          • 993
          IIRC the 1st model had an adjustment for mixture or something
          • Flat on my back
            • Jan 2007
            • 2449
            Originally posted by BRY
            Thats not the one i'm fitting, yes there are 2 versions but for the life of me cant remember if mine is the early or late one...
            Carlos.
            • Cullam3n
              • Aug 2007
              • 993
              early version has a red cap over a screw next to the block on the side to adjust something to do with the mixture
              • Flat on my back
                • Jan 2007
                • 2449
                Try here for pics...
                Carlos.
                • psiconauta911
                  • Oct 2007
                  • 613
                  • Country: Portugal
                  thanks
                  Thank you all for the quick reply.
                  The one on ebay is not the ONE!
                  The one I need is the same as the one in the SAUGER-TUNNING site http://www.20v-sauger-tuning.de that is tubular shaped and not contorted like the ebay one, and I only need the carcass as I´m using the sensor i have.
                  Pedro
                  • psiconauta911
                    • Oct 2007
                    • 613
                    • Country: Portugal
                    again
                    Yes there are 2 models and I need the the 2nd probably the one that Carlos has.
                    Pedro
                    • psiconauta911
                      • Oct 2007
                      • 613
                      • Country: Portugal
                      the part number is 078,133,471 because of the screws that hold the sensor to the MAF only this one will do.
                      Since the ones that have A or AX in the part number have the screws in the opposite location and won´t work.
                      Pedro
                      • Flat on my back
                        • Jan 2007
                        • 2449
                        As well...
                        If you're considering this mod, you will also need higher flow injectors (Bosch 0 280 156 095) and a remap or fit a 'piggy back' ecu, such as an Perfect Power SMT 6.
                        Carlos.
                        • psiconauta911
                          • Oct 2007
                          • 613
                          • Country: Portugal
                          Thank you Carlos, The injectors are already in and it is now running a bit rich and after the MAF I´ll have it maped with a piggy back ecu.
                          Pedro
                          • Flat on my back
                            • Jan 2007
                            • 2449
                            Star...
                            Be good to compare results. I have the RR results on mine with a full ss ex system (decated), high flow air filter and some holes cut in the airbox, oil breather venting to air instead of back into the engine and new low impedance injectors...slightly better flow than the Hitachis.
                            Your mods are my next upgrade as well.
                            Carlos.
                            • psiconauta911
                              • Oct 2007
                              • 613
                              • Country: Portugal
                              Well Carlos mine isn´t really a 7A but a NM, 1994cc 160hp at 6200rpm, it as a tubular exaust manifold and no cat. I´ve changed the hitachi injectors for the bosch ones from 034 to the 7A (that´s the reason why it´s running rich) and open the lower front part of my air box (ram air from under the light in a protected away from heat area, nice intake sound) I have a KN panel air filter.
                              Since this mods I noticed a nice improvment, from 3000rpm to 5krpm(off cam 4500 on cam), of 0,5 seconds in full throtte(from 6,67secs. to 6,06secs.).
                              I´m waiting to get the enlarged maf to install the piggy back and tune it properly.
                              Pedro
