hole in manifold
  • hoffer76
    • Mar 2008
    • 230
    hole in manifold
    Hi everyone some more advice needed please.
    my new manifold has got a hole drilled and some kind fitting welded into place I
    have no idea what this is for also does anybody know what kind of manifold it is
    all help appreciated.
    Looks like an MTM SQ manifold, the hole is for an EGT probe - Exhaust gas temperature
    • terrybullwon
      • Mar 2006
      • 8782
      Jamo's right, how ever... Not the best place for a probe as if it melts and snaps off, its going to go through your turbine
      Chef
      • hoffer76
        • Mar 2008
        • 230
        thanks Jamo I'll see if I can get one of those egt probe kits any idea of good supplier in uk
        • hoffer76
          • Mar 2008
          • 230
          maybe I will have it removed and welded back up them thanks
          • terrybullwon
            • Mar 2006
            • 8782
            You can just blank it off, with a screw on cap. If you messure it, i may have one you can have. What turbo are you going to use wth this manifold and if you don mind where did you find it?
            Chef
            • hoffer76
              • Mar 2008
              • 230
              It seems to be approx 5mm with a course thread don't have my calipers to hand, I have a garret gt3071r and I found the manifold in Germany last year, thinking of using the 034 motorsport chip tuning package gt3071r stage 1 do you think its a good idea or not?
              http://www.034motorsport.com/product_info.php?cPath=22_109&products_id=1220[/URL]
              • hoffer76
                • Mar 2008
                • 230
                should of asked if manifold is suitable for desired 400hp
                  It will likely be fine.
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    Yeah It will be fine for 400bhp, what flange is on your turbo?
                    Chef
                    • hoffer76
                      • Mar 2008
                      • 230
                      I think its a t3 flange the bolts seem to line up I am a little concerned because the profile on the inside of manifold is round poss kkk27 and the turbo is rectangular as shown in pic
                        You need to buy a new turbo hotside with the K26 flange, Axis motorspot can get them or you can buy from ATP direct.
                        • terrybullwon
                          • Mar 2006
                          • 8782
                          Thats what i was getting at Jamo... Great minds and all...........
                          Chef
                            I'm just wondering if hoffer76 could get away with using the T3 flange.........
                            As the manifold has a K27 flange on it and not a K26, it does not have a raised lip on it
                            I'd get a t3 gasket and see if the two will mate together. Lets face it the ATP K26 hotside is just a machined T3 hole to take the top and bottom lip of the K26 raised round hole.
                            • hoffer76
                              • Mar 2008
                              • 230
                              Yes Jamo thinking the same
                              This is what it looks like with t3 flange there is very little interference think I may try it.
