hole in manifold
    That will work, you need to check the gasket goes around the outside of the hole though, it should do as the T3 gasket is quite a bit larger than the flange.
      You could also get the manifold machined to a true T3 hole size. It is possible with the way the manifold has been made.
        http://www.034motorsport.com/product...pqv6ha9hh40is4
        This may do the trick K27 to T3 convertor
        • HPmuirt
          S2Forum April Fool
          • Apr 2005
          • 3014
          That is a much nicer solution than just mating up a square and round hole as that huge flat surface area would surely have a nasty effect on the gas flow
          However, at $125 plus shipping to Blighty , I would pop down to your local machine shop with a couple of brown drinking vouchers and get one made up yourself
          Cheers n
          Si
          Subtle mods here and there
          2011 A5 3.0 TDi - Lava Grey
            Personally I'd machine the manifold if I was doing it. Suppose it depends on if you want to sell the manifold on in it's OEM state.
