Hi all i have been told there is a need for weld sockets to mount your gas temperature probes into your manifold/pipes.
There are 2 sizes all in St/St,
size 1 is: 25mm(dia) x 15mm long
2 is: 30.8mm(dia) x 15mm long,
If needed i can reduce the size of the diameter to 15mm, they need shaping/grinding to the manifold or location you are going to weld it too, i will fit an 1/8"bsp plug so that when you are grinding and welding the socket to suit, the threads will be safe.
If people need them just PM me and tell me what diameter you need, note a thicker wall will reduce weld distortion a bit.
Graham
Graham
