RS2 downpipe and cats on 3b engine possible?
  • LeoLeandro
    • May 2008
    • 26
    • Country: Switzerland
    Hi guys.
    i'm new there.
    fist thing, sorry for my bad english i'm from switzerland and my main speaking language is french .
    Actually i'm working on my s2 3b to have a little more power and i've a little question.
    it is possible to plug a RS2 downpipe and 2 RS2 cats with the original exhaust of the 3b with out any modification of the exhaust?
    or i've to buy a bigger or little middle exhaust to plug this one on my s2 3b?
    Thank you in advance for the answer.
    best regards.
    Leandro
  • MikeLarwood
    • Aug 2008
    • 278
    Don't think so - the 3B exhaust won't mate to the RS2 downpipe and cats from what I can see on the drawings. It may fit if you get an ABY exhaust but I don't know if all the hangars are in the same place.
    Sorry I can't be more help!
    • s2driveruk
      • 12696
      downpipe is definately different, just found that myself........Mike knows my disappointment, though I am sure he'll benefit from my misfortune
      The 3b is a single pipe, then a Y sections bolts the the bottom of the downpipe, whereas the RS2 is cast as a single unit with the two outlets for the cats to bolt up to.
      Also the cat shape and pipe dimensions are totally different - definately not compatible with the 3b setup.
      David
      1992 3b S2 Coupe
      • Jonas_R
        • 3781
        • Country: Denmark
        www.bn-pipes.de they have different SS exhaust pipe system.
        Sleeper S2 Avant +450
        A6 Avant 2.7t Stage 3
        Audi S2 Coupe RS2'ed
        • LeoLeandro
          • May 2008
          • 26
          Hi.
          Thank you for all your answers.
          i've contact BN-pipes a little time ago and the society have tell me, The downpipe is only compatible with the RS2 ADU and S2 ABY.
          maybee if i put the middle part of the exhaut from a ABY in my 3b this one can be adapted?
          Thank you and best regards.
          Leandro
          • Wolfgang
            • Mar 2006
            • 250
            hi leo,
            you should take the following parts:
            RS2 Downpipe
            RS2 or S2 ABY Cats
            The RS2 or S2 ABY Sedan / Avant Y-Pipe after the cats
            And then you have to connect the Y-Pipe of the RS2 to the Middle-silencer of the S2 3B. This is going to work, you don´t need the middle-silencer of the S2 coupé aby.
            If you want to solve it with the S2 ABY Middle-silencer, the way would be this:
            RS2 Downpipe
            RS2 or S2 ABY Cats
            The 2 single pipes after the cats from the S2 ABY Coupe
            And the S2 ABY middle silencer
            the big advantage with this solution is that it´s plug´n´play, and there is no "Flex" or welding machine necessary. The disadvantage of this solution is that you have to buy a middle silencer and the two pipes after the cats of the s2 aby coupé.
            The difference between S2 3b and s2 coupe aby middlesilencer is that there is one single pipe in the s2 3b and there are 2 (!!) pipes from the cats to the middle-silencer in the aby.
            concerning the end-silencer i can only say that there is a difference in the part numbers but i can´t see a difference if they are lying in front of me.
            Perhaps there had been a change in the end-silencers which cannot be seen from the outside or whatever.
            Hopefully this is a help you,
            PS: a hot adress in switzerland for S2/RS2 parts is www.totsteile.ch
            wolfgang
            S2 Coupe ABY
            S2 Sedan
            S6 20V Avant
            www.audis2.de
            • LeoLeandro
              • May 2008
              • 26
              Hi Wolfgang.
              thank you for all your informations.
              with this one, now i know what i've to find to make the convertion.
              thank you i know TotsTeile, some parts of my car come from there .
              Best regards.
              Leandro
