Dahlback cone??
  • Floppy
    • 126
    Dahlback cone??
    Hi all,
    I'm thinking of buying that dahlback open air filter kit.
    But... does it straight fit in a 3B?? Or do you have to bend pipes and stuff?
    And another question> which dump valve is good for a 3B? And what are the differences with 'AN6' connection??
    Thanks!
  • Sweeper
    • 1317
    • Country: Latvia
    I have this one. But I lost the filter somewhere :/. Should be a straith swap.
    Vadim.
    New engine (mechanical PKM head) , Alcon 332mm brakes , Pauter rods , Mahle pistons, GT30R , kw v2 sucpension , new exhaust. 608HP. For SALE !
      • 12431
      I think tom is arranging with a local firm to make something similar for the S2 that will be a bit easier on the pocket.
      • audiman
        • 4827
        Yeah, i am, but i need some measurements from an original pipe etc. Plus sizes of the sheild, blah, blah, blah. etc etc etc
        Tom C - www.rcmr.co.uk
        Audi UR Quattro
        Audi 100 C3 2.0 5 cyl 115ps
        Audi B5 RS4 645ps 911nm
        • s2avant
          • 2426
          It would appear to be a pair 80mm diameter 90º bends welded together. Can't help on the shield though.
          I was going to make something from silicon elbows but I'll wait till you've done some investigating.
          Ben
          • Sweeper
            • 1317
            • Country: Latvia
            Will be able to provide you with the details/measurments in few days. I'ts in a garage.
            Vadim.
            Vadim.
            • audiman
              • 4827
              cheers sweeper, the pipes are offset too i think. But by how much??
              Audi UR Quattro
                Tom - I have zee Dahlback one for recce purposes !
                It can be improved I reckon as the heatshield sits mighty close to the MAF, and a longer nose on the pipework would facilitate more filter choices.
                The actual heatshield isn't a bad fit either but I'd use a better material than a straight piece of aluminium sheet.
                Paul
                  • 12431
                  I guess the cone setup uses a piece of hose between the stainless and the MAF so its not rigidly mounted.
                  • porkkis
                    • 1994
                    I've been trying to source 80mm 90deg bends without success.
                    • s2avant
                      • 2426
                      Dahlback list them on their site but they aren't cheap. They are hidden in with the flanges IIRC.
                      Ben
